turbojimmy
Aug 22, 2015Explorer
You state that it's dying on hills. If it runs at all, it's not likely the fuel pump. If you really had 0 pressure on the output side of the regulator, it would not run at all. You have to measure pressure with the engine running (ideally when it's misbehaving), or during the three-second or so fuel pump prime when you turn the key on.
Need more symptoms for a guess at the cause. When you say it won't climb hills, what's it doing? Just no power? Any backfiring or sputtering?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
