eHoefler
Aug 22, 2015Explorer II
You need to check fuel pressure on the supply side of the regulator, not the return side. On the return side you have nothing to restrict it to build pressure, it is open to the tank for return. The regulator is what causes/makes the fuel pump build pressure. You need to connect your gauge to the carburetor/fuel injector side of the regulator.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
