D_E_Bishop
Aug 23, 2015Explorer
This is what I know so far,a 1989 P30 has an in-tank, I do not have access to the repair manual and the OEM number. Pumps for Chevys of that vintage have an out put pressure of 12 to 30 pounds. According to the speed shop where I bought the regulator and a whole bunch of mechanics, the delivery pressure to the on the block fuel pump is 4.5 to 5psi. I have set mine as close to 4.7 as possible.
I have located six or seven pumps that look like mine does(Isaw the old pump, not the entire assembly)that are for Chevy's of that era but not the specific pump and associated specifications.
As far as testing the pressure before the regulator, I would only learn what the pump output pressure. Now that I have the delivered pressure set all I am concerned with is, does the carb get that pressure when I am going up hill with the pedal to the metal and the secondary's open.
I found the fuel pump relay thanks to Mexicowanderer and a graphic I located by Googleing, "1989 Chevy P30 Fuel Pump Relay location" Google not Yahoo or Chrome.
I removed the relay and disconnected it from it's five conductor plug and cleaned the contacts and opened the relay housing to watch the operation of the relay. According to the schematic and written description, when the ignition key is turned on, the pump will run to build up pressure in the float chamber, you then depress the throttle, "ONCE" and release. Then you turn the key to start and the power to the pump is interrupted to prevent flooding of the carb. When the engine starts, and builds up oil pressure, the relay holding voltage is supplied through the oil pressure switch.
I watched my relay and it operated normally. I was able to watch the fuel pressure on the gauge. I bought 20 feet of hose to enable me to have the gauge in the cockpit when I was at the wheel.
Now here is what I am guessing about but education, experience and common sense make me 85 to 95% sure I know what I am talking about. I had several things to do before I could do a test run, you have to know that all this is taking place in my storage yard and I have to be very neat and orderly and not spill anything on the asphalt. Because I needed to run the engine in my Sidekick. Wash the window of the sidekick so I could put the solar battery minder in it, clean the windshield of the MoHo and juggle three vehicle in and out of parking so as not to block any other renters parking spaces.
All told it took about an hour with the engine running and the temperature gauge was at the high end of it's normal range. As I drove up to the exit gate and started out I noticed the pressure gauge was reading "ZERO". I pulled out, turned around and went back to my space, opened the doghouse removed the relay cover and the relay was no longer actuated.
The relay was very hot and when I could get it up on the cover on the floor the coil read "0" ohms. I think that the coil is bad, both ends are a somewhat darker color rather than the lacquered color of a copper wire while the center of the coil looks normal.
This would account for the engine running very strong when we first start off but start to starve out after about ten to twenty minutes later. Even my wife picked up on that.
The answer to the question about the gauge is; I forgot the name of the manufacturer, it is American made and measures from 0 to 15 psi. It is oil filled for a couple of reasons, the most important to provide dampening of the vibration often found in race cars. It cost about $35. As I said earlier, I bought the Holley regulator when the original Holley part failed and was leaking all over my SIL's parking area. Both the regulator and the gauge were purchased from a very highly respected speed shop in Pasadena, CA by the name of Blair's Speed Shop. [COLOR=]The Holley regulator is not a tee with a restrictor, it is a diaphragm regulator just like a propane regulator. The pressure is critical in race engines.
The staff at Blair's also offered some what to do's if the relay was good including to make sure the return line was functioning. Because I have been there off and on since I was 16 they are nice to me.
Thanks to j-d for the picture. We also have several resident bob cats in that area and at least two within 200 yards of our house.
If I forgot to mention it earlier I have the stock Quadrajet carb.
If I failed to mention anything other than the site where I got the graphic and schematics, it is because I have to Google it and wanted to get this out first. I'll post it later.
Thanks to all and when I pick up the relay and do a test run I repost and tell about it. I may not get out to storage until next weekend because we're off up the coast to find some cool if possible and good calamari steaks if nothing else.
Dave
Dave
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
