StirCrazy
Mar 03, 2022Moderator
Gdetrailer wrote:
Current price of FLA 6V GC2s at Sams club is running about $90 each or $180 for 168Ahr at 80% use or 105Ahr at 50% use..
$180 FLA is still a lot less than $299 for Lithium.
If weight is a factor, Lithium wins on that aspect.
If cost is the factor, FLA wins hands down.
If it comes down to life, FLA can easily last 7-10 yrs even with using as much as 80% of the capacity.
Track record of lithium life is still in flux and not really known for sure and what little published information is out there is typical manufacturers over hype to sell a product.
guess we need a bit more ballance here haha' you forgot the size advantage also ;)
you not going to get full life of a GC2 running at 80% capacity, you will get the min life usaly around 680 cycles and your definatly not going to get 7 to 10 years with a costco or sams club GC2 maybe 3 to 5 running that load level. now if you spend the bucks and get a GC2 like a rolls surrett ya you could probably get 5 to 7 years at that level. but what we forget about in Lead asid batteries is the Peukert effect, so while we thing we can get x apmount of AH the harder you draw the less you actualy get, plus the ineffiencies in resistance that works both on charging and discharge. for example to use a deicent microwave in my 5th wheel I had to install 4 GC2 batteries so the voltage would stay high enough for a reasonable amount of time to prevent the inverter from going into alarm, and even then once I start getting close to that 50% capacity all it does is alarm. thoes are four good quality 6V batteries that were close to 300 each (canadian) using my discout from work so about 1200 worth of batteries proabably close to 1500 with out my discount. so when we look at cost vs preformance then LFP wins hands down. Ill use my expensive lead asid batteries to give a fair comparison .
4 batteries for 480AH = ~240 usable AH for maximum life estimated to be around 1000 cycles for 1200 bucks . so over the life of the battery used at 50% capacity if we asume it dies at 1000 cycles, which would be a good life it will have provided 240000AH at a cost of $1.00 /200AH
now if we take two average LFP say 500 bucks each (kinda a middle price now) for 100AH each and I'll even give you that I'll only use 90% of the battery ... actualy Ill do two, becasue there cycle life is a 100% usage rating. so 200AH for 3500 cycles for 1000 bucks give you 700000AH over the life at a cost of $1.00/700Ah
but this is only the start. thoes two LFP will stay above 12V output untill aproximatly 10% capacity and have such a low Peukert effect it is concidered unimportant, so this means at a high amprage draw you would get the full capacity instead of a lower amount. this combined with the voltage numbers will alow you to dive much deeper into the lower end of the battery before your inverter starts alarming resulting in even more real world capacity.
as for the life bay cycles it is not a unproven number but what people fail to understand when you say the life of a lead asid battery that means it is normaly done and needs to be replaced after the number of cycles. With the LFP the cycle life is just to the point to which the battery is reduced to 80% of its original capacity (kinda like how the life span of solar panels are rated) so lets say that 200AH bank was used at 100% capacity for 3500 cycles (or what ever the manufacture states the life is) it is now a 160AH battery which could last even longer than the original as the degradation slows as time goes on. this is the part that is unknowen, how long can you use it as a 160AH battery , could be 5 year, 10 year or 20 years...
now is LFP the perfect battery, nope close but has some draw backs. cold weather camping being the most significant one, but can be overcome if you want to. charging. to get the best charging to them your going to need to change out your charge section of you power center, but if you have a WFCO I recomend this anyways lol. as for BMS, I wouldnt worry about them as they are part of the battery.. not really many stores of them going bad, probably just as many stores of "I bought batteries at sams club and there no good after 3 months....
the only advantage I see in getting lead asid batteries at the pricepoints out there now is if ou just don't have quite enough to get thoes LFP batteries you buy the cheep sams club or costco batteries to tide you over. thats what I did this last summer when my expensive batteries gave up the ghost after 13 years. bought four costco batteries (160 each up here though). this will last me till shipping comes back down battery cells.
Steve
