jkwilson
Sep 20, 2017Explorer III
BFL13 wrote:
"You don't want to connect batteries of different capacity or condition in parallel."
Yes to condition, no to capacity. No problem paralleling different capacity batteries. They charge and discharge in proportion. They maintain the same voltage and SOC.
The charger tuned to stop at 1a per battery would stop at 2a on the pair.
The problem with paralleling different capacity batteries is that the discharge curve isn't linear. Once you draw a certain amount of power, the smaller of the batteries can become a load on the larger. It will work, but you don't get the capacity increase you might think you are getting. Your actual capacity will be close to two of the small batteries in parallel rather than the sum of the two.
