i charged up the batteries last night and this afternoon i will test to see if things are working. the plastic on the battery fuse was partially metled. if i had a loose connection on the battery, could that be the cause of the melted fuse? the other problem is I removed the fuse and now cant get another one in because one of the holes seems to be clogged up. i'll try and open it up with a screwdriver later.
if i cant get this resolved i may be camping with no power, which sucks because it might snow. if i have no power, will the propane powered appliances like the fridge and stove still still run?
