Smegolas wrote:
the plastic on the battery fuse was partially metled. if i had a loose connection on the battery, could that be the cause of the melted fuse?
Yes. Loose connection make a poor connection, which means higher resistance, which means heat when current flows through that resistance. The heat can melt the plastic. My inverter melted the plastic insulating mounts when they loosened from vibration. Every time I drew over 100A, I could smell melting plastic.
if i have no power, will the propane powered appliances like the fridge and stove still still run?
Fridge - no,
Stove - probably yes.
