enblethen
Nov 05, 2014Nomad
Look closely at the power section. You may need to only replace the neutral buss bar. You can get them at most hardware stores or electrical supply house.
Melted wires are mainly a sign of a loose connection. The neutral buss bars are commonly aluminum. The wire is copper. This is considered dissimilar metals and requires the use of an electrical de-oxidation grease.
If you have sufficient slack in the conductors cut the bad ones back to a point where there is good clean fresh copper, install the new neutral buss and re-terminate the wires applying a good coating of de-ox grease.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
