time2roll
Aug 18, 2014Nomad
KevSchofield wrote:
I'm looking at this one.. has one less breaker, but I'm assuming I can move one over from the bad unit?
45 amp converter WFCO
Amazon has the 55 amp version for $151 and change.. any advantage to going that route?
NO, NO, NO do not get a WFCO. And you do not need the whole power center. Just replace the converter portion that is sitting in the lower slot.
Converter has 5 wires. 3 for 120vac power in, Hot, Neutral, Ground. And 2 for 12vdc output B+ & B-. Possibly a chassis ground.
Get Progressive Dynamics or IOTA for all camping styles including charging batteries from a generator. PowerMaster is OK if you are mostly plugged in.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
