KevSchofield
Aug 18, 2014Explorer
Got it on the WFCO.. Been reading that that is not the way to go..
It is sounding like I can just replace the bottom part there, and that is only the battery charger?
Doesn't seem right as I was plugged in to campground power when the 'low voltage' alarm on the propane detector went off.
It starting chirping and my battery meter was reading empty.. I assumed that lower section does other stuff besides charge?
If I'm plugged in to power, whether through a generator or actual power source, why would
the low voltage alarm on the propane detector be going off?
Is it because only my 12V things were affected and they normally run through the battery being
charged and that is just continuously monitored and charged by that lower section while you are plugged in?
Sorry if I'm not being 100% clear.. I'm trying to wrap my head around how it works.. Never had an issue before~
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
