dougrainer
Mar 26, 2015Nomad
enblethen wrote:
Sounds like you have one of these. The item shown as #2, switch pulses the smart box that actually operates the slide. There could be issues inside of the black box or a wire is loose.
E Z slide
Clicky for Dou's post
Doug:
Does this convert the push type button to a rocker?
Yes, the original was a hazard, so they redesigned to prevent operation unless you HOLD the button. Back in the mid 2000's, due to a injury caused by a slide room that extended without holding a button (not barker) all the OEM and slide makers redesigned the slide controls to where you MUST hold a button to make the slide continue operation. No recall, they just had the controls redesigned. Doug
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
