Wot? Why would anyone be worried about corrosion?? :R
Here's what the mini-breaker in our A-frame looked like after a year. I don't see any corrosion, lol!
The 2nd photo is what the ground lug in the A-frame looked like after a year. I replaced it with two new larger lugs with more surface area and the connections are soldered and wrapped with heat shrink tubing. I made it a redundant ground setup and attached the lugs on opposite sides of the A-frame with stainless steel self-tappers. While I didn't use it, a little dielectric grease might help too. The ground lugs they use aren't approved for wet locations but they all seem to use them.
The converter will also be grounded with a bare and insulated ground wire to the frame (probably near the converter). We had a a couple of similar ground lugs like the above one attached to the frame. Think of all the water thrown up by the tires. The green wire was being hit by the tire all the time and would have worn through at some point. I replaced the original lugs with a brass grounding split type stud intended for wet locations. One of these studs would be a good choice for the grounding in the A-frame.
I went a step further and relocated all the splices and breakers in our (typical) 4x4 metal box into a watertight PVC box. Some of the marrettes were upside down and filled with water. Some of the wires were tarnished and I dipped the ends in acid before soldering the splices.
