SkiSmuggs's avatar
SkiSmuggs
NEMA L5-30R Twist Lock to 30 amp straight adapter
I plan to get a companion cable to connect two 2000w generators, but the end is NEMA L5-30R female Twist Lock and my RV electric is an RV 30A male.
The companion cable does include a NEMA L5-30P male plug to aid in making an adapter. Is that pretty straight forward? I can do outlet installs, etc, but am not an electrician.
THIS might be what I am looking for: http://www.amazon.com/Honda-L530P-RV30R-Generator-RV-Adapter/dp/B00864S2CU
  • RoyB wrote:
    The AMAZON reviews look pretty good on those adapters. Alot of time any small adapter like this is pure trouble and prone to failure from loose and bad connections. The DOGBONE type long adapters were always much better in this respect.
    Roy Ken
    Agreed and my 50a-30a and 15a-30a are both dog bones, but alas, these don't come in that form. I ordered the Camco as it looked the cleanest.
  • RoyB's avatar
    RoyB
    Explorer III
    Roy Ken
  • Turns out that Camco and Conntek both make them for less than the Honda model.
  • NinerBikes wrote:
    If you buy Honda connectors for Honda Generator, it comes with the plug adapter for your travel trailer.
    Thanks, it took a lot of searching to find it, but the "Generator RV plug adapter" keywords would have been a big help.
  • If you buy Honda connectors for Honda Generator, it comes with the plug adapter for your travel trailer.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
