enblethen
Nov 27, 2018Nomad
Gensets permanently installed in an RV have the neutral and ground bonded together. The one pictures is for permanent RV mounting. Ground should not be switched in transfer case.
Verify which transfer switch you have. Transfer switch should switch phase conductors and neutral.
Many portable gensets do not. It that case you may need to tie the neutral and ground together, This lies to some power systems so they operate correctly. Surge suppressors for one.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
