BFL13's avatar
BFL13
Explorer II
Nov 27, 2018
Neutral to Frame vs Floating Neutral Question
Been discussed here a few times, but can't remember the difference if any.
Onan here has neutral bonded to frame and it is for RV use.
https://www.usedvictoria.com/ReportSelectUsedAdPhoto2?used_ad_id=32655856&position=3&hb=1
Typical portable gens have floating neutral and we don't use their chassis grounds. With that Onan are you supposed to link the chassis ground to the RV frame?
In a motorhome set-up, how is that done? (that one in the ad came from the guy's 5er apparently )
  • I was assuming the LP Onan in the ad is a portable gen, while the ones you see installed in MHs are different. I obviously don't have a clue about Onans, but am curious anyway.
  • Not sure of the question, but for an rev specific Onan, th3 neutral and ground are bonded, as the Onan is the power source. Both hot and neutral are switched in the transfer switch, so they are not bonded while o; shore power.
    I *think* that neutral and hot are bonded in RV specific inverters as well.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
