rbp111
Oct 19, 2013Explorer
nev-r-lube axles
I own a 2003 Alpenlite fifth-wheel trailer(which I am very pleased to have). The trailer has nev-r-lube axles. I have taken the trailer in the past and had the axles checked out along with other item...
RAS43 wrote:RJsfishin wrote:
You can believe it or not, in theory wheel bearings are good for life !
But that only works if they always had grease, and never had water, moisture, or dirt in them.
Also, they have to be adjusted correctly! Too loose or tight and longevity is much shorter.
