I own a 2003 Alpenlite fifth-wheel trailer(which I am very pleased to have). The trailer has nev-r-lube axles. I have taken the trailer in the past and had the axles checked out along with other item...
Dexter only warrants these bearings for a period of 5 years. Considering the cost of a new hub and bearing as well as possible damage brought on by a failed bearing. I will have all 4 of mine pressed out and new bearings installed every 5 years. By the way, the Dexter hub and bearing is very costly. Timken (not sure of part #) replacement bearings are much cheaper and if replaced before the hub is damaged even better to replace early.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
