Lostagain__ExplorerAug 20, 2013Nev-R-LubeI found that Napp has an SKF bearing that they keep in stock. Part number FW115 with steel seal's and there only $43.99. My self, I replaced the axle's with Dexter Ez-lube hub's. After reading up on t...Show More
Ron3rdExplorer IIIAug 20, 2013Interesting first post.Thousands and thousands are running those axles with zero problems.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related Contentnev-r-lube bearingsDexter 8k axles, nev-r-lube bearingsNev R Lube bearingsnev-r-lube axlesNev R Lube bearing replacement
