I found that Napp has an SKF bearing that they keep in stock. Part number FW115 with steel seal's and there only $43.99. My self, I replaced the axle's with Dexter Ez-lube hub's. After reading up on t...
Never Lube is one area where there are few, if any, negative issues; lots of comments about EZ lube mostly over greasing and grease getting behond the seals. And the OP went from Never Lube to EZ lube based on comments (on this forum?). Too bad he did not share where he read up on the negative Never Lube comments.
