Lostagain__ExplorerAug 20, 2013Nev-R-LubeI found that Napp has an SKF bearing that they keep in stock. Part number FW115 with steel seal's and there only $43.99. My self, I replaced the axle's with Dexter Ez-lube hub's. After reading up on t...Show More
byronljExplorerAug 21, 2013The part number from the op is for a 42 mm bearing. The never lube bearing for my 7k axles calls for a 50mm bearing.Dave
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related Contentnev-r-lube bearingsDexter 8k axles, nev-r-lube bearingsNev R Lube bearingsnev-r-lube axlesNev R Lube bearing replacement
