Lostagain__'s avatar
Lostagain__
Nev-R-Lube
I found that Napp has an SKF bearing that they keep in stock. Part number FW115 with steel seal's and there only $43.99. My self, I replaced the axle's with Dexter Ez-lube hub's. After reading up on the nev-r-lube bearing and the failure rate. I want to go on vacation not to find out the axle's are junk. Every dealer I spoke with said pretty much the same thing. There nothing but trouble and if you can, get rid of them. So I did. I ended up working with Tex Trail in Ocala, Fl. on rt-441. They bent over backward's to help. If your in the area, 1-800-259-8712.. Found them on the Dexter web site.
  • So you removed your axles because of what you have read on the internet, what about all of us that have never reported any problems. I did change ours out at 8 years and 75K miles because one was running warm but it was still within end play limits. I like the Nev-R-Lub because I don't have deal with grease. Dealers don't like them because they can't service them so it's less money in their pocket.
    Denny
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
