SaltiDawg
Apr 28, 2015Explorer
I would assume one has to enter the Tare weight of the cylinder - it's stamped on the ring collar.
Only intended to work with the 20# cylinder.
"The weight of your propane tank is located on the collar. The number will be similar or the same as the numbers preprogramed into your GasWatch: 16.6lb, 17.0lb, 17.6lb, 18.0lb, and 19.0lb"
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
