SFVdave's avatar
SFVdave
New 2 stage PD lithium Converter charger yet?
When I installed lithium batteries 18 months ago I also changed out my converter charger. I didn't want it constantly charging 14.4 volts. so I returned it and have been using my original PD converter charger and just hit the charge wizard to get it fully charged. With 300 watts of roof top solar and an MTTP controller, it stay fully charged shile camping. But I heard that PD was going to produce a 2 stage one that drops to 13.6 after fully charging the batteries. Wondered if they came out with it? Can't find it on their site if they did. they have changed the num,bers around with upgrades so I may have missed it.
  • 3_tons's avatar
    3_tons
    Explorer III
    When the need arises for occasional battery top-off (primarily just for cell re-balancing…) I opt for either the Charge Wizard (above about 95% SOC, actively monitored via Victron BMV 712), or when off-grid, a programmable 2 stage BlueSky solar charge controller set respectfully at 14.4 & 13.6 volts…I see no real need to swap out the PD…
    3 tons
  • Even 13.6 continuous is a bit high. I would stick with what you have.
    Also charging the lithium at the absolute max 14.6 volts is overrated and unnecessary.
    The 13.2 - 13.6 - 14.4 profile is better. Especially with minimal use due to solar.
    yes they have a whole line of two stage chargers for Li out now.
    Steve
  • Keeping Lithium batteries at a constant 100% SOC isn't recommended by most manufacturers.
