Cartwrk's avatar
Cartwrk
New AC leaking and dirty inside
We just had a new non-ducted ac installed, got back to camp and started running it and it's leaking a significant amount of water onto the floor from the filter. After taking off the filter and looking at the interior we found it's pretty dirty inside the middle part. The exterior shroud and lower panel look new. Is it normal for the inside of a brand new unit to be dirty inside after running for a few minutes? It's leaking so much water we have to keep a pan under it. I'm now concerned about the integrity of the rv repair shop that just installed this.
  • Sounds like you got taken. Sorry to hear. Go back and demand a full refund. No point getting it done by the same dishonest place. Or better yet, go to a different place, explain the situation and ask if they'll take a look and give their opinion to back you up when you go for the refund.
  • Used unit and possible dishonest/lousy installer. Not a great combo.
  • Take it back. Tell them to do it right, and test it before you pick it up.
  • sounds like they installed a used unit on your rv. and didn,t even do a couple hour test run.
  • YES I would be concerned.....
    New A/C Unit should not be dirty inside the Evap Coil area or Room Fan discharge plenum unless the 'installers' were careless and damaged plenum/sidewalls during install
    A/C Unit sucks room air in...cools it and discharges back into room
    NO outside air connection
    Is the Return Air Filter Dirty??
    As for all that water...evap coil can drip condensation
    That should go into drip pan under the evap coil and have drain holes that allow the condensation to drain off and run away from A/C Unit....drip off of roof at whichever corner of rig is lowest
    Sounds like drip pane drain holes are blocked and condensation is NOT draining out'
    Could be Debris from the dirty installers
    Could be the 'installers' tightened the hold down bolts TOO much crushing the roof gasket and A/C Pan is too close to roof so drip pan drain holes are blocked
    New gasket should have been used
    New gasket is 1" thick and hold down bolts should only be tighten enough to compress New gasket by 1/2
    Hold down bolts should only be SNUG
    New gasket was used correct.....old one would have been crushed already
    Way too many RED Flags with the installation!
