MNtundraRet
Aug 23, 2013Navigator
Quote:
"Checking with volt meter should be done not "after charge", but 24 hours after charge. Full battery with all cables disconnected should read 12.7V."
Not true in this case. Since a load such as refrigerator and detectors will get rid of a surface charge with minutes. Checking the voltage at the battery-terminals about 15 minutes after charge (all other items left turned off) should work. Fully charged battery-bank should drop to 12.7 volts. Anything higher is still surface charge. Check again in 15 minutes.
If the battery-bank is less than "full charge", the voltage will settle at something lower (i.e. 12.5v -90%, 12.4v -80%, 12.3v -70%). The items I mentioned left on do not cause a voltage drop so reading is good enough for accuracy. I hope he is not starting each cycle 12.3 volts (70%) already or he is in "deep dodo". Heavy sulfating of the batteries already.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
