We are ready to head to Montana next week, from Alberta and today I found out that my battery is pretty much toast, Deep cycle batteries run about at about $175- $190 dollars here in Canada. Just...
Before spending a lot of money on fancy batteries, what are you using them for?
If you were otherwise happy with the old battery, there is no reason to move up to higher end batteries.
This would be common if you typically stay in campgrounds with electricity. Enough power to run the jacks, slideout, maybe a bit of water pump if you stop for lunch...you simply don't need the cost or weight of a big battery bank.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
