Bought a new Interstate 12V battery (Not a forever battery)for the TT on the 3rd of June to replace one that was totally dead. Hooked it up with a battery cut-off switch that I bought from Camping Wo...
The battery cutoff is attached to the negative terminal and then the negative battery cable is attached to the cutoff. It uses a bar to open/close the connection. Never really used it except to test it out. Was going to use it when I returned to the storage unit to not drain the battery. When I got back, I removed the cutoff unit and just disconnected the battery cables.
Yes, I think I will take the battery back to Interstate for them to check it out.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
