Bionic_Man's avatar
Bionic_Man
New Coach Batteries
It is about time to change batteries in the coach. I have the standard two 12-volt system, which I think I will stay with. But I am considering going to AGM batteries.
When we camp, we usually have electricity. At least until fall when we put the boat away, and then we switch to more federal lands in the mountains without electricity. The RV is stored at home, and is left plugged in so that we don't have to load/unload the fridge every trip. I do my best to add water to the batteries over the course of the year, but sometimes I forget.
Would there be an advantage to going to AGM batteries in the above scenario?
  • AGM is a bit more sensitive to undercharging. Best to verify the charging system meets the charging specs of the new battery.
    Yes there are advantages to AGM. No corrosion, no water to check, some resistance to freezing, a deeper discharge is better tolerated, higher resting voltage, faster charging, higher CCA rating for high load items (less voltage sag).
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
