Want to pull new cable from booster to antenna, which one on back of booster goes to antenna. The one in the bedroom is orange but there is no orange one leaving back of booster
Another thing to consider. There are usually two INDEPENDENT lengths of coax between the switch and the antenna.. One runs inside the wall to a connector at, or just under, the roof line, this cable is protected from the effects of the sun and may well outlast you..
The other is from the roof to the antenna and 99% of your cable problems are with this run.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
