Old-Biscuit
Jul 23, 2016Explorer III
RobertL0 wrote:
I appreciate all the reply, thanks guys!
I do not have the pendant, I manually push the button on the board.
During my charge, either 10 seconds or 5 minutes into into the cycle, when I push the button, the LED light will change from steady green to blinking green, but the voltage and amps does NOT change as reported on the TriMetric..
TriMetric is probably indicating voltage correctly.
PD/Wizard is probably NOT going into BOOST
BUT verify what the DC OUTPUT is using another meter....handheld digital voltmeter and see what PD s putting out and IF it changes with different modes selected.
IF it doesn't.....boost circuit is non-functional
Easy to verify..right on front of converter
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
