MrWizard
Jul 23, 2016Moderator
RobertL0 wrote:
I appreciate all the reply, thanks guys!
I do not have the pendant, I manually push the button on the board.
During my charge, either 10 seconds or 5 minutes into into the cycle, when I push the button, the LED light will change from steady green to blinking green, but the voltage and amps does NOT change as reported on the TriMetric..
You just turned boost OFF
Solid green light is boost mode indicator
Blinking light is normal absorb mode
It may not be working when it is supposed too
But but you turned it off, so no way to know
Leave it on solid green and give us volts to go with the amps
Volts should be rising but it could take awhile to see the rise depending on battery condition
TriMetric are nice, but at this point it is possibly out of calibration
Batteries should be charged until totally full this is going to be hours and hours then calibrate the TriMetric
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
