pianotuna
Apr 30, 2016Nomad III
It is a known observation that the PD input does not "like" all generators. It is also known that it may not initially get to 14.4 volts if the battery bank is hungry.
RobertL0 wrote:
I replaced the WFCO converter in my 2015 class C with a Progressive Dynamics PD4655, since we boondock and would like to charge my 2 house batteries quicker when using the onboard generator.
I also installed a TM-2030 battery monitor.
The two house batteries are 24DC-4, which have a reserve capacity of 130 min each
Last week, while boondocking, I observed the TM-2030 showing a 55% battery charge remaining and fired up the generator. I saw the green light lit steady on the converter circuit board stating that we were in "boost mode".
But according to the TM-2030, the volts going into the battery was showing 13.6, not the 14.4 boost mode should provide.
I hit the Charge Wizard button to cycle through the 3 modes, but still it only showed 13.6 volts in "Boost Mode".
I have the wiring schematics for the coach and they used 2 gauge cables in all battery connections.
I did not run the generator too long that morning so I never timed how long or how many amps was put back into the battery.
My question is, why did the converter NOT go into "boost mode"
Thank you in advance
Rob
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
