GuyCanRV
Jan 30, 2022Explorer III
dougrainer wrote:
Top of switch the Black and White wires should have 120 between them. You can see the power cord come in the bottom of the switch. THEN you have to check power thru the 120 tstat. Then just check for 120 at the 120 element wires. Doug
Thanks Doug.
I didn't get your response before I had closed it all up.
What I did was check for continuity between the two white wires.
I figured when the switch was in the right position, giving continuity, the electric current would flow.
It seems to be working.
The fridge is cooling down nicely now. :)
GuyCanRV
Dec 09, 2023Explorer III
Well time for an update and a question.
Less than two years after my cooling unit came back from the repair guy my fridge stopped working.
He tried to troubleshoot the problem and was reluctant to blame the cooling unit but after everything else was eliminated the finger was pointing to the cooling unit.
So I'm getting ready to ship it back to the repair guy in a few days.
When I removed the stack and its insulation the bare pipe inside was exposed.
I saw this pipe for the first time and noticed at its bottom, where the heating element
fits inside, it was all white. A fine dust powder was covering it.
The pipe appears to be disintegrating.
Is this normal? When/how soon would this occur in a unit?
Thanks!
