exp2ex's avatar
exp2ex
New electrical issue
First, Thanks for all the help received with my power converter problem. My factory one was bad. I replaced it with a power max which was a simple fix and less expensive then what I was expecting.
Next. My AC, fan and lights etc are all working as designed. The only issue I am having is with the BATH GFCI outlet and the fridge.
With the camper plugged in, the batter cables connected, the battery reads 13.12 V at the battery and 13.10 V at the lugs in the panel. all breakers in the on position, and the GFCI receptacle on, if I turn the fridge on, the BATH GFCI will trip at the GFCI. In a few minutes the CHECK light on the fridge will illuminate.
This happened with the old power converter as well. It is the only thing that has stayed the same.
Also, If I turn the all the breakers off in the box, the fridge buttons will still illuminate. Is the fridge 12 V ?
Thanks again
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
