DrewE
Jan 11, 2020Explorer III
The converters are not battery size specific, at least not in terms of everything working or not working. (If you were to change to a much larger battery bank, a larger converter would be sensible so it doesn't take forever to recharge.) Most likely something is not wired correctly, or a connection isn't sound, or possibly the battery disconnect switch is set to storage mode, or something of that ilk. If things were connected improperly, there is the chance that you may have damaged something in so doing.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
