opnspaces
Jan 11, 2020Navigator III
STOP, you are wired incorrectly disconnect all the negative wires now. You have the 12 volt batteries wired in series making 24 volts.
Per your pictures you removed two 6 volt batteries correctly wired in series and replaced with two 12 volt batteries. The 12 volt batteries need to be wired in parallel. let me find a picture.
Here, you need to be wired like the batteries in the LEFT picture. Your old wiring is in the right picture.
Hopefully you did not blow any fuses. But you'll find out after you correct the battery wiring.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
