MEXICOWANDERER
Nov 03, 2014Explorer
DIRECT FROM THE MORSE'S HOUTH...
Pro-24M (ECL)
12 Volts – Cranking / Deep Cycle
Marine / RV
BCI Group No.: 24
Cold Cranking Amps (CCA): 550
Marine Cranking Amps (MCA): 690
Reserve Capacity: 140 minutes
Warranty Months: 12 months
Dimensions: 11" x 6-7/8" x 9-1/2"
Terminal Type: SAE Post & Marine 5/16” Stud
Weight: Approx. 46-lb.
Plates: N/A
Construction - Flat plate, liquid lead acid, Low gassing
Case Material - Polypropylene
Grid Construction - *Positive – lead, calcium - low gassing Power Frame design.
Grid Construction - *Negative – lead, calcium alloy, expanded metal design.
Case/Cover color – White Case, Green Top
SAE compliant Polypropylene Handle
Testing compliance- RC/CCA SAE J537
Specific Gravity – 1.285 to 1.300
*Positive and Negative plate thickness is Proprietary to Interstate Batteries, Inc. and cannot be released
So, they're going to try it again. Calcium / Calcium, in a "Deep Cycle" battery. Only they're juicing up the density of the electrolyte to make the specs look prettier.
Any company that believes withholding plate thickness specs is a given "right" has something to hide. You couldn't GIVE me one of these things...
Just my humble opinion
Pro-24M (ECL)
Marine / RV
BCI Group No.: 24
Plates: N/A
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
