beemerphile1
Jun 05, 2018Explorer
MrWizard wrote:
yes.. only 10amp, its a 1200w continuous use, 1200w/120vac=10amp
why should the pass thru TS be larger than the output load of the inverter ?
( so someone would be tempted to carry a larger hard wired load, larger than they should, and the inverter give an overload fail when it is needed ? )
im not using it anyway...
Since you aren't using the pass thru it doesn't matter but it seems small.
I will be installing a Xantrex inverter/charger in a friends rig and even though it is 2000 watts the transfer switch is 30a.
