moisheh
Jun 06, 2018Explorer
1200w is not enough to safely run a MW. Most draw more than 10 amps. If your inverter has a transfer switch then all the circuits you mentioned will be running through the inverter even when hooked up to power. You wont be inverting but the current will go through the transfer switch . It wont handle lots of power draw. If you are not running any outputs to the transfer switch how will you get power to those items you mentioned?
Moisheh
Moisheh
