MrWizard's avatar
MrWizard
Moderator
Jun 04, 2018
new inverter for Bounder 'UPDATE FAILURE'
installing this tomorrow, too tired today
does NOT come with cord and receptacle
designed for hard wire install
Click For Full-Size Image.
Aims 1200/2400 PSW with 10amp transfer switch (10*120=1200)
i'm not using the TS/pass thru function
Amazon $169 Aims 1200w PSW
1200w continuous 2400w surge, MW is 750 cooking watts, 1100 input watts
this should power anything i want to power, maybe not my circular saw or welder, but everything else
primary use TV, laptop, fans, device charging
secondary MW late at night (other wise i would have got something with less power)
  • Yes the stock arrangement has been changed (3) batteries NOT just (2) GC
    i have a small Heat pad, i keep by the bed, use it for a few minutes most nights
    just to relax my back,
    turning it off before dozing off, is the tricky part
    been thinking about adding a timer, set it for 30 minutes, then lay down
  • Even my 4024 Trace grunts when starting an old Skilsaw worm drive. Too heavy for me now that I'm old and weak.
    A nice addition Mr. Wizard! Time to think about a tiny heating pad for frosty winter mornings!
  • MrWizard wrote:
    Approx 350ampHrs of battery
    The MW use seldom hours over (3) minutes
    Late night bacon only takes 30 seconds
    Early morning coffee warm up (2) minutes
    Make a pot of coffee (10) minutes, normally with generator
    But can do with inverter IF desperate
    Curious, has the OEM battery arrangement of 2 6s been changed?
    2 premium 6s would be about 220 ampsHrs. 4 budget 6s would be about 416ampHrs.
    Inquiring minds want to know.
    Richard
  • Approx 350ampHrs of battery
    The MW use seldom 'SEES' over (3) minutes
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
