Buckleup
May 25, 2014Explorer
Therink, the lavatory drain connects to the shower drain and it passes directly through the floor into the gray tank, no leaks above the tank entry at the floor. This is why I believe there should be some kind of seal that has failed. I will probably call our dealer on Tuesday when they open before I drop the tank. Looks like one metal bar with four bolts to be removed and the pipe to dump valve that will have to be cut and the tank should come down.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
