OldSmokey
Jul 26, 2017Explorer
DieselBurps wrote:
I don't think 48 volts is worth it unless you start going above 400 amp hour capacity in lithium. When you get above that with lots of solar, you can start to really use some high draw appliances without thinking too much about it.
Batteries are not the problem with solar RV, it's the inefficient solar panels that limit use. most, if not all RV's have insufficient roof space to accommodate the panel watts you need for high capacity appliances. when solar panels hit at least 50% efficiency then we can all run high draw appliances.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
