darsben
Oct 04, 2014Explorer II
westend wrote:
If Gary owns a 454 and seems to love it, you'll be fine. He will have a work ethic above what you can get elsewhere.
I don't know if Californians are unaware of the nuances of smog tests, the testing must be similar to other areas of the country. We had mandatory annual testing in MN until the populace got disgusted with the scam and it was abolished. During that time, myself, and every other backyard mechanic, discovered how to make even the worst oil-burning V-8 pass emissions testing. Here's the recipe: Change oil and filter, run gas tank down to 1/8 of a tank. Add a quart or two of isopropyl alcohol into the tank. Drive to the testing center. I have seen vehicles that were unable to pass emissions testing even after a full tuneup, pass with 0.0 on the test readouts after the alcohol addition.
90% isopropyl not the 50% that is common
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
