MrWizard's avatar
MrWizard
Moderator
Dec 06, 2018
New Meter on order
wireless power meter
Volts , Amps, KwHr, AmpHr, capacity, SOC, etc...
sender and hall effect coil go at battery
display goes where-ever (as long as in signal range)
No pulling wires between the (2) pieces
going to mount sender at the battery (of course)
going to put display over the fridge where the fuse box and breakers are
the furnace is under the fridge, and no easy way to pull wire inside from the battery in basement or the OEM house mount up front behind the grill
converter is in basement, with my add-on 4D agm
meter should arrive middle next week
$40 on ebay
I went looking after remembering somebody (Mexi?) had posted a link many months back
