MrWizard's avatar
MrWizard
Moderator
Dec 06, 2018
New Meter on order
wireless power meter
Volts , Amps, KwHr, AmpHr, capacity, SOC, etc...
sender and hall effect coil go at battery
display goes where-ever (as long as in signal range)
No pulling wires between the (2) pieces
going to mount sender at the battery (of course)
going to put display over the fridge where the fuse box and breakers are
the furnace is under the fridge, and no easy way to pull wire inside from the battery in basement or the OEM house mount up front behind the grill
converter is in basement, with my add-on 4D agm
meter should arrive middle next week
$40 on ebay
I went looking after remembering somebody (Mexi?) had posted a link many months back
    $40 on ebay
    Following
  • Jeeze I guess they're weren't joking when they said "special introductory price" of $24.99
  • there are (3) electronic pieces , be sides the various wires
    the 'Hall effect sensor' (not a transformer), yes it connects to the data sending unit
    the 'data module/wireless sender which can power the display'
    the display unit which can be used wireless and powered separately from the data sender
    this one can be powered by 6-60vdc
    can measure 0-120vdc, and 100amp
    think of the display as a combination remote display and keyboard
    think of the sender as the data accumulation module and remote connection to the display
    the hall effect device is the current flow sensor
    voltage measurement is taken by the data unit from its power input line
    there are units that measure 200, 300, 500 amps
    i will follow after it is installed
  • Yep the sending unit has it's own power supply. Try extending the receiver wire to around 40" then changing orientation.
  • Could be I suppose the transformer is wired to the sending unit I suppose.
  • agesilaus wrote:
    RLS7201 wrote:
    The link you posted shows the sender and meter are connected by USB cable, not wireless. Can you show us the link to what you purchased, that is wireless?
    Richard
    If you read the description it does say 'wireless' and describes the 'transformer' as a hall effect device.
    is the USB cable then an alternative means of connecting the transformer to the meter?
    Richard
  • The link you posted shows the sender and meter are connected by USB cable, not wireless. Can you show us the link to what you purchased, that is wireless?
    Richard
  • Alfred622 wrote:
    After you get it, and figure out how to install it, could you test it out and post the results here?
    Ditto on that
  • After you get it, and figure out how to install it, could you test it out and post the results here?
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Apr 17, 2023
