mahaney's avatar
mahaney
New power center
So, this isn't really an issue as much as an opinion question. I need to replace my converter/charger on my rig and am really thinking about just replacing the whole thing-A/C and D/C side at one time with either the Boondocker 4 stage power center or the Progressive Dynamics PD4060 60 Amp Inteli-Power Mighty Mini Power Center. What would be the draw back to replacing the entire system vs. just the converter on the bottom of the unit? Full disclosure, currently I have the 6300 series, 6325 model, Parallax/Magnatek center.
Has anyone done this, if so, would you do it again as I am sure there will be issues with re-wiring the new system into the old space and possibly having to come up with some creative ways to mount the system.
thanks
J
  • Follow up:
    Replaced converter/charger with boondock 4 stage today. Huge shoutout to Randy and his team at bestconverters.com. Talked to him on Thursday around lunch time, converter was sitting at front door yesterday (Saturday) afternoon.
    Install took about 3 hours but mostly because there was a good amount of modifications needed for unit to go into existing housing. Put meter on leads at battery after install reading 14.6 V. Didn't have a couple hours to let genny run to charge batteries, but not a difficult installation at all.
    I did have to call them for clarification on wiring the new board.
    J
  • I talked to a fellow from best converters this morning. His recommendation was to not change out the AC side since there are no issues with it. I went with the boondocker system and will only have to change out the converter/charger and the board on the DC side. Thanks for the input, I appreciate it!
    J
  • What your battery needs or not should play a role in recharging or sustaining capacity.
    If you do not stress your breakers, have no history of tripping breakers and the distribution wiring and contacts are in good shape I would think that favors not doing a panel changeout.
    The bigger the difference between actual usage amperage and amperage recharging potential of a charger gives an idea of The Comfort Margain of the charger. Underworked chargers last a lot longer than a maxxed-out charger.
  • Thanks guys. The only reason I was thinking about replacing both is due to the fact that it is roughly $200 either way. With the unit being 30 years old, I figured I might as well do the whole thing at one whack.
    And yes, I was thinking about upgrading to a 60 amp center since I have been adding stuff. I might just stick with the 45 amp though.
  • So, You want to replace the 6325, which is a 30 amp ( 25 continuous ) with a new converter that is 60 amp ?????
  • I replaced my Magnetek converter and didn't replace the power panel. I didn't see any reason to. Mine was the 7300 series however.
    If you have a problem with the power panel or think it is just too old, consider getting a kit that includes a converter and power panel.
    Here is a link to one source.
  • I disconnected but left the POS converter in my power center as an emergency spare. I mounted a PD9260 next to the battery compartment in the basement of my 5er wired to the battery with battery cables from local auto store.
    Doug
  • D.E.Bishop wrote:
    I have an old PD power center and converter, when it started acting up, it was easier to just slap in a new converter and use the same distribution panels
    No cabinet work, no wire shanges. I wouldn't change the distribution panel unless there was a problem.
    That's what I did with my wfco. I replaced the conv with a 55a Boondocker 4 stage. Direct replacement. Problem solved.
  • I have an old PD power center and converter, when it started acting up, it was easier to just slap in a new converter and use the same distribution panels
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
