TomandCandy
Nov 06, 2014Explorer
Golden_HVAC wrote:I
What is your battery voltage?
My guess is the battery is low and the voltage might go up to 13.0 after a few hours to charge the battery. What was the battery voltage before plugging in the converter? If say 10.9 volts, then 11.5 is actually pretty good improvement.
You might also have a tripped circuit breaker or fuse between the battery and converter. This can also happen if the fuse is smaller than the new converter output, IF the battery was low enough charge to accept more amperage than the wire and fuse is rated at. . .
So tell us the battery voltage, and we will get back to you. If battery is less than 11.5 volts, plug it back in and wait until morning, and check the voltage again. If over 12.8 volts, then a dead battery caused the low voltage, and it should be normal by afternoon!
Fred.
Fred I think your right I just didn't want to burn up something bran new the voltage reading is the batteries and yes after hooking back up everything the voltage is moving up pretty good after 20 minutes its up in the 12 volt range now with lights and stuff on so I guess sometimes ya got to pause sometimes even though I don't like to every body had good ideas on what may be wrong but I had ruled those out already thanks Tom.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
