OK, got the starting issue fixed, and thanks to all here who offered help and suggestions. Now to a less critical but still annoying issue. To work on the starter we had to raise the unit of on the...
It sounds to me that your jacks are retracting all the way but your lights on your dash does not show that because they are still lit. Is that correct? If so I would look for a switch that controls the light. On mine it is a mercury switch mounted to the top of the jack itself and every once and a while I have to clean the ground to get it to go off. The ground is a wire with a terminal grounded by a small machine bolt.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
