OK, got the starting issue fixed, and thanks to all here who offered help and suggestions. Now to a less critical but still annoying issue. To work on the starter we had to raise the unit of on the...
The jack alarm light on mine is signaled Via a float switch in the reservoir If fluid is low it will alarm even with all jacks retracted, occasionally it sticks, and will signal not retracted, with jacks up and fluid is marginally enough and jacks working, To replace the internal float switch would be a messy slow process, can't be done without removing reservoir from pump
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
