211Racing
May 27, 2022Explorer
New Roof Time! Can I just layer over the existing plywood?
Got an old, unkempt 2002 Tioga 25' Class C RV recently (really cheap). Fixed the mechanical issues. Now going after the roof. Whatever they last used for a roof membrane, it is almost completely gone. Bare plywood in many places. Some dry rot. Did exploratory surgery this morning with a hole-saw. See the images. The plywood forming the exterior roof and interior ceiling is approximately 3mm thick. Between that roof and ceiling is 3" of foam (presumably injected). The adhesion between the plywood and foam is very strong. What problems do I cause myself if I leave the current plywood in place, strip, clean and seal it, patch wherever needed, than lay down (put up) a new 5mm plywood layer on the roof and ceiling? This will be a low-use vehicle, mostly for day trips to motocross/hare scramble races (need someplace to cool off). I am willing to accept the added weight. Thank you for your insights and shared experiences.
[img]
[/img]
[img]
[/img]
